Holes with interrupted cuts / offset holes, how to cut?
Bentworker
Post by Bentworker » Fri Dec 28, 2018 2:59 pm
One of my projects has been drilling some aluminum alloy wheels for a different bolt circle. Where I am drilling there is an existing 1/8” (roughly) dia hole about 1/2” deep that was used to secure the cap.
The drill for the new hole has it’s web entirely in uncut material, but the existing hole is in the diameter of the new hole. Clear as mud? You can see it not so clearly in the picture.
Using an edge finder and some math I fool with the wheel until I get it clocked on the mill table where the existing lug pattern is about as square as I can get it within sanity (less than 1/4 degree).
Then I clamp the daylights out of it and check it again.
Here is what I am doing with decent results, are there better / faster ways of achieving the same or better results?
Using math & DRO I go to all 5 coordinates and complete one step, then change tools.
1) Peck drill the through hole (about 1 1/4” deep) using a 9/16” drill. The cut is interrupted for the first 1/2”
2) Rough drill about .570” deep with a 1” drill for the counterbore.
3) Finish the through hole with a 5/8” end mill, raising the knee to cut.
4) Finish the counterbore with a 1 1/8” end mill raising the knee to a depth of .600”
5) Cut the taper .200” deep with a 60 degree countersink.
So far I have had satisfactory results with the finished hole centerlines +/- .002” radially from the centerbore.
What tricks are there? Anything else besides using a boring bar?
Thanks for your time,
Peter
Shop toys...
Jet 13x40 lathe.
Powermatic 1150 drill press.
I love Craigslist!
Re: Holes with interrupted cuts / offset holes, how to cut?
Post by John Hasler » Fri Dec 28, 2018 3:32 pm
Predrill with a bit small enough not to intersect the existing hole.
Surely it's only the taper that needs to be precise, as long as the through hole and counterbore are close enough to clear the bolt shaft and head.
Post by GlennW » Fri Dec 28, 2018 9:17 pm
I'm curious about the boring bar comment.
Do you not have one?
Bentworker
Post by Bentworker » Fri Dec 28, 2018 10:40 pm
I have a boring bar, but it only gets taken out for special occasions.
Shop toys...
Jet 13x40 lathe.
I love Craigslist!
Glenn Brooks
Post by Glenn Brooks » Fri Dec 28, 2018 11:18 pm
In similar situations, I’ve had good success drilling my initial hole over the top of an existing hole using an end mill, rather than a drill bit. The end mill doesn’t deflect and cuts where placed, unlike a drill bit. Afterwards, you can enlarge as necessary, without difficultly.
earlgo
Post by earlgo » Sat Dec 29, 2018 10:43 am
If I am not mistaken the torque from the drive train or brake disks is transmitted to the wheel thru the lug bolts. By adding the holes between the holes, you have reduced the wall thickness to about 1/4 to 1/3 what it was. The wall crush strength may give you problems in extreme torque transmitting situations. You might be able to alleviate that somewhat by tightly plugging the old holes and counterbores. This looks sketchy at best.
JMHO
--earlgo
Post by BadDog » Sat Dec 29, 2018 2:36 pm
I did this exact thing on Thursday. But in my case it was a steel bracket for a custom engine mount crossmember that needed both larger hardware and moving over slightly. End cutting end mills are just the thing.
Post by BadDog » Sat Dec 29, 2018 2:45 pm
It is my understanding that if the bolt shear is restraining brake or accel induced torque, then the system is flawed and already doomed in much the same way as restraining a taper drill with the tang. Even if all else was more than up to the task based on an FEA, there is always clearance, which means movement and hammering, which means eventual failure.
Again, as I think I understand it, the real key here is clamping with resulting high static friction to transfer torque loads. Which is another reason for the importance of properly torqued wheels, more so on higher performance applications.
However, some wheels are hub centric, and others are lug centric, the latter typically having cone seats to address accurate location with the required clearance. And I've heard folks claim the cone seats transfer for torque, but also that they are wrong in that claim.
At least that's my understanding. I'm no engineer, so I'm fully prepared to be wrong...
warmstrong1955
Post by warmstrong1955 » Sat Dec 29, 2018 3:04 pm
You are 100% correct Russ.
Clamp load is what transfers the torque, not bolt shear. If it comes down to bolt shear, it's because your wheel was loose...and yeah....wheel fastener torque is very important, with both designs. Bolt shear would require 'body-fit' studs & wheels....not an inexpensive endeavor.
Heavy equipment moved away from both conical & spherical wheel centering to center pilot (center hub) centering years ago. That's all the taper/cone/spherical design is for....centering. Conical and spherical (Budd) nuts are pretty much a thing of the past, and have been replaced by hex-nuts with hardened (SAE) flat-washers.
I am much more familiar with off road equipment design, but I know many automotive designs are taking the same path.
So Russ....you be right!!
Engineer? I think it's spelled injunear.....
Bentworker
Post by Bentworker » Sat Dec 29, 2018 9:13 pm
Thanks guys,
The endmills worked well, but I am always curious what others are doing to accomplish the same thing.
Shop toys...
Jet 13x40 lathe.
I love Craigslist!
Orrin
Post by Orrin » Sun Jan 13, 2019 1:07 pm
I visited a shop this last week that featured a rack with a complete set of annular milling cutters in sixteenths. At first, I wondered why; but, the more I thought about it, it seemed like a brilliant idea. An annular cutter might have been the perfect solution to this problem.
So many projects, so little time.
duckman903
Post by duckman903 » Mon Jan 14, 2019 6:20 pm
If these are for you all well and good, if for another person don't charge them and if asked you never saw them.
