Another round column mill spindle bearing question
Moderators: Harold_V, GlennW
Sftyvlv
Post by Sftyvlv » Sat Apr 13, 2019 3:45 pm
I see alot of guys changing spindle bearings out. Is this because of necessity or just because?
Do many still use the stock bearings/lube and have you had issues?
armscor 1
Re: Another round column mill spindle bearing question
Post by armscor 1 » Sat Apr 13, 2019 4:09 pm
Running at prolonged high speed cooks the bearings, changed mine only once over 12 years, avoid high speed at long intervals let the bearings cool.
Sftyvlv
Post by Sftyvlv » Sun Apr 14, 2019 8:28 am
Thanks Armscor.
