Emcomat 7
BradW_SA
Emcomat 7
Post by BradW_SA » Wed Nov 26, 2003 12:49 pm
Wanted: accessories and spares for an Emco Unimat Emcomat 7 lathe. Anything considered, especially a tailstock and set of changewheels. Would even buy an incomplete, worn or damaged machine or parts.
Any advice on a currently available machine with changegears that would fit the Emcomat 7 would also be appreciated
Mikey
Re: Emcomat 7
Post by Mikey » Fri Dec 05, 2003 9:54 pm
Hi brad
Did you find any help..I own a Emcomat7(my 3rd) so I can't help you out with parts,or accessories...I'm looking too.
But I've been in the same spot you are, and would be happy to help out with measure-ments or whatever.
These Emco's are great little machines,well worth the effort
The "lathe master"8x18 seems to offer a source of compatible parts...you might try ordering one gear from him to see if they mesh.
the tailstock could work too if you have the base re-machined.
Good luck
