The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Sat Jul 31, 2010 1:12 am
Post new topic Reply to topic  [ 89 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Author Message
 Post subject: Truing up jaws in lathe chuck
PostPosted: Wed Dec 14, 2005 8:25 pm
Offline
The jaws in my 3jaw lathe chuck seem to have a wopple when a piece of shaft is chucked in them. the shaft doesn't seem to be centered in the jaws. What harm would it do to just run the boring bar thru the open jaws and try to true up the center. I dont do precision turning or sale my work. I just use the machine for making a few short length shafts for hinges and pins. Lathe is 14 in Monarch. The jaws look like something has turned inside them and boogered up the jaws and I am just wantint to take off enough material clean them up. Is this possible or do I need to just buy new jaws.
Top
 Profile
 Post subject: Boring Bar
PostPosted: Thu Dec 15, 2005 8:31 am
By itself, the boring bar MIGHT be able to true the chuck, but the jaws need to be firmly anchored against something, or they are going to wobble all over the place as the bar 'cuts.
Hence the clamp piece that is around the same diameter that you want the jaws to be true at.
Without it, well things just aren't likely to be quite what you expect them to be.
Top
 Post subject:
PostPosted: Thu Dec 15, 2005 2:35 pm
Offline
If you're familiar with the use of soft jaws, you understand that the jaws need to be loaded in order for the corrective action to yield acceptable results.
You can restore the jaws to quite respectable condition, but I'd suggest you do it this way:
Open the jaws to a given diameter, large enough for a grinding wheel to enter the opening. It need not be a large wheel, a mounted point (3/4" or so) will suffice. When you have an opening that is acceptable, use either a washer that is an acceptable size, or make a thin disc of the proper diameter that can be chucked at the very deepest part of the jaws. It should be round, not irregular in shape. Make certain that the disk runs true (no flutter side to side) when you tighten the jaws, so the pressure is at right angles to the spindle. Allowing it to lean will generally yield a poor job because the jaws will not be loaded properly against the slides. You'll grind up to the disc, then kill the miniscule area after grinding.
An older chuck has usually experienced considerable springing, so the jaws grip only at the rear. By loading the jaws as suggested, the jaws will spread to the sprung condition, leaving the jaws out of parallel. Your grinding operation will then make them parallel, so they grip front to back in use. You load the jaws as suggested so they aren't free to move about while you're grinding them. The disc will load the jaws such that they will be held captive, generally in the general position they occupy in use. That provides for a correction of eccentricity as well as correcting the angle of the jaws.
It is recommended that you seek the best of the three holes in your chuck, then mark it. By using that hole when tightening the chuck, you'll minimize the amount of error in chucking. Don't expect an old chuck to repeat within anything less than .003" as you move through a range of sizes, but it should grip squarely after you've ground the jaws.
I keep talking about grinding, avoiding your talk of turning. It's a pretty tall order to expect tooling to stand up to the rigors of the interrupted cut and the hardened condition of the jaws. Even if you could get the jaws to machine, you'd be hard pressed to get them machined from front to back without considerable grief. You'll be far better served to try grinding them. If you don't have access to a tool post grinder, you might investigate the possibility of using an air or electric grinder firmly clamped to the toolpost by some means. I've done that with reasonable results, even though they don't have high precision bearings. As long as you're not trying to hold tenths, you might be pleasantly surprised at the results.
Good luck with the correction. Why don't you give us a report when you get the job done, and tell us how you did it.
Top
 Profile
 Post subject: Deja_vu
PostPosted: Thu Dec 15, 2005 3:26 pm
All over again.....
Top
 Post subject:
PostPosted: Thu Dec 15, 2005 4:58 pm
Offline
I had considered the grinding wheel but had planned on chucking it in the tailstop and letting the lathe turn the three jaw as I fed the wheel into the jaws. Will that work? I hadnt condidered that I might should place somesort of band around the outside of the jaws to hold them stationary. I suspect that a band around the outside of the jaws would spring them inwards and leave a taper. The washer chucked just at the furthermost inside of the jaws is probably a better solution to the springing. This chuck is old and I aint sure of the make, I dont see any markings to reference off of. I am sure it is older than me.LOL For information, the number one jaw seems to be the one that is out of wack, when tightened on a piece of shaft you can almost see daylight between the jaw and shaft material. The chuck has been taken apart but each jaw is stamped and is in the correct position. I also checked to see that the jaws where installed in the correct order. something at one time or other has slipped in the jaws and left grooves in the jaws. Hopefully just grinding the burrs off will cure the problem. I didnt really pay much attention to the wobble until i tried to drill a hole in the end of a shaft, most of what i do just isnt that critical. I guess when I get the wobble fixed i will find something else that needs to be improved just a little more than the way it is. LOL
Top
 Profile
 Post subject: Grinding
PostPosted: Thu Dec 15, 2005 5:03 pm
Never thought about the grinder in the tailstock.
I have always put the grinder in a location where I can adjust the wheel position so that it is easy to grind off what is needed....hence a toolpost grinder or some 'equivalent' that you can rig up to do the same thing.
You can actually purchase these truing rings from people like MSC, but I see little point when most of us have more than enough scrap around.
Keep in mind that chucks don't always wear evenly...often it is the scroll that wears as well as the jaw, so truing a chuck at one diameter is no guarantee that it will be true at another...
Food for thought, even if it is cat food...
Top
 Post subject:
PostPosted: Thu Dec 15, 2005 5:38 pm
Offline
Yeah, what Bill said. The wear on the chuck alone will be cause for mixed results, which is why I suggested that you shouldn't expect any better than maybe .003" concentricity, assuming you do your job well. Even new, universal chucks aren't perfect. The scroll is typically machined before heat treat, so it's subject to minor deviations from that process alone. Still, there's no reason you shouldn't get reasonable results, assuming you do the grind properly.
The idea of a ring on the jaws is fine as long as you have some kind of fixturing that holds the jaws as if you had clamped on a piece of stock. You can imagine some kind of bridge device that goes over the end of the jaws and supports them from the tapered portion just past the gripping surface. Truth be told, that would be the best way to do the job, because it loads the ends of the jaws and expands them fully, which is what you're supposed to do in order to make them grip parallel. The ring in question would require considerable more setup time than a simple disc does, and the disc, applied properly, will do a very good job.
I suggest to you that you do not use a ring, where you expand the jaws to restrain them. If you do, you'll compound your problem. What that does is cause the ends of the jaws to lean in instead of out, then when you grind them, the taper will have more or less doubled. It's very important that you follow the instructions in principle if you want to improve the chuck, even if you find a way around one or two of the steps.
Grinding from the tailstock would work fine, assuming you have a means of feeding the wheel. As Bill said, it's better if you have complete control over how it feeds, and how fast you can move it while grinding. You're quite limited as to speed with a tailstock, and feeding the wheel could prove difficult unless you have some kind of slide mechanism you can install in the quill. If not, I'd strongly recommend you concentrate on the compound, maybe not even using the toolpost. It really is the best of all worlds for the task at hand.
Top
 Profile
PostPosted: Thu Dec 15, 2005 5:45 pm
all over again....
Top
 Post subject:
PostPosted: Thu Dec 15, 2005 9:08 pm
Offline
I had the same problem on my lathe when I first got it. I tried using a grinding stone w/ 1/4" shaft mounted to the tool post, It helped true up the jaws a little but, ultimately, I found that the register on the backing plate for the chuck was too loose (.005" undersize), and the face of the backing plate needed to be trued. I eventually ended up replacing the chuck (I really wanted one with 2 piece jaws) and making a new backing plate from a plate of round stock. Then I found that it really pays to use a torque wrench when you bolt up your chuck to the backing plate!
Top
 Profile
 Post subject:
PostPosted: Thu Dec 15, 2005 9:28 pm
Offline
I made myself a clamping device with 6 pieces of keystock welded to an iron ring. This made in effect, three slots that the jaws fit into and I put in setscrews to clamp against the jaws. Result is that when you tighten the chuck slightly, the loading on the jaws is almost the same as if it had something chucked in it. I then use a heavy duty hand grinder mounted in the toolpost to true up the jaws. Of course as has been mentioned, just because you have it running true at one diameter, doesn't mean it is true at another one. Most of my work is done at less than 1" diameter and the chuck will hold small work and run within .001" concentricity after grinding.
Unka(I could post a picture of the set-up, but have to make one first)Jesse
_________________
Top
 Profile
 Post subject:
PostPosted: Fri Dec 16, 2005 12:54 am
Offline
Ok...I have one for you guys.
I bought a 5" Buck three jaw from Fleabay. It threaded right on my old SB and of course it is worn and has about 4 thou of run out.
I want to put it on my 6" R/T for my mill.
I was going to turn an adapter for it that threaded in the back and slips into the MT3 center hole in the R/T.
How can I grind the jaws true in this application?
Ha...I no longer have the old SB to do it with.
I thought of mounting it in the 4 jaw on my 14" lathe but that won't work...how can you indicate it? What would you indicate? I don't see that working.
Only thing I can think of is to make the adapter...screw it in the chuck and do the truing before I turn the MT3 "spiggot" to slip into the R/T.
Then I'm not sure how to grab the adapter to do this(to turn the short MT)...it will have threads where it needs to be grabbed.
Could make another adapter for it to screw into so I could hold it but this all sounds like the possibilities for error are pretty big.
Any ideas?
Thanks!
Top
 Profile
 Post subject:
PostPosted: Fri Dec 16, 2005 1:00 am
Offline
That particular setup is great, but it must be properly indexed. If the interval between supports isn't identical to the chuck, you risk tilting a jaw sideways when it's tightened. Not a big deal if the chuck is fairly tight, but if it's quite sloppy--it can be. Even then, you'd improve the chuck, though. The real benefit of grinding the jaws this way is to improve jaw to material contact. Chucks that grip only at the rear are a real PITA, causing excessive chatter and making it difficult to keep parts round, as they oscillate in and out under the pressure of the cut as the material flexes between support points.
I was going to comment earlier about the suggestion that one jaw appeared to be all the trouble. While it's a long shot, it's possible the chuck has been through a crash, where the part exited the chuck by forcing on jaw out, which would surely lead to some kind of damage. The description of the chuck tends to support the idea. Before attempting any kind of repair, it might be a good idea to remove all the jaws and examine the slides to see if there's any substantial differences in them. Even though a chuck might be improved, it's possible that any given chuck has simply outlived its useful life and you won't get the benefits expected. Just a thought.
Top
 Profile
 Post subject:
PostPosted: Fri Dec 16, 2005 1:26 am
Offline
Any ideas?
Thanks!
Sure!
Why won't it work? You have a good idea, but it must be executed properly.
Look at this as if you're building some custom tooling (which I did for years as a tool maker when I ran my shop).
Chucks, when made, are intended to be true with the body. If you chuck the smaller chuck in your 4 jaw, dial it true in both directions, restrain the jaws as we've discussed, then grind the jaws, it will be just as true as if you had mounted it by the thread. The important issue here is for you to really have it dialed true----which will take some patience. Don't let "that's close enough" get into the decision---for any error you introduce here will be with you from that day forward. It's worth spending the time to eliminate down to a couple tenths. Even closer if you have means to read that close.
Start by stoning the face and OD of the chuck body, so there's not any dings to drive your indicator nuts. The smoother the surface, the better. Set the pointer of your indicator so it trails off any openings, and don't have much "preload" on the indicator, so it doesn't bounce much. Turn the chuck by hand, always in the proper direction, so you never stub the point.
What you're doing in this instance is making certain that the jaws are concentric with the chuck body----even if they weren't originally. Makes no difference--you establish a new reference point, which is what you need for the balance of the work at hand. Remember to mark the hole (for the chuck key) you intend to use in the future, and always use that hole-----not the others. Make the mark permanent, so it can't be confused.
Once you have your chuck ground, as long as your locating pin conforms to the same setup, it will have little choice but to be true when applied to the rotab. I'd pay strict attention to the back side of the chuck, too. Make sure it's dead parallel with the front, which will have been your second reference point.
This is one case where I detest a tapered center in a rotab. I will use them only with a straight bushing. That way you are free to provide a locating pin without the worry of how long it must be in order for the chuck (or any other fixture) to seat properly. I'm not keen on the idea of a chuck being held only by the taper, particularly when you risk spinning the chuck as you would on a rotab, perhaps milling a large radius.
What I recommend is an adapter plate (aluminum works fine) for the chuck, which is held to the chuck by the backing plate bolts (the adapter plate replaces the backing plate, if that' possible), then the adapting plate has counterbored holes that match the T slots in the rotab. That way you can mount the chuck securely. That, of course, won't work if your rotab is not larger than the chuck.
Top
 Profile
 Post subject:
PostPosted: Fri Dec 16, 2005 1:40 am
Offline
Harold...Thanks! I wasn't sure if the outside of the chuck was a sure way ti indicate the setup. That makes it easy then. I can also machine the MT with the adapter screwed into the back of the chuck....as long as the thing is square on both sides I guess.
No...I wasn't going to hold it in the R/T with just the MT plug.
I'm going to do just what you said. Machine a 1/4" steel backing plate and bolt it into the T-slots.
As you can imagine, there isn't a whole lot of room as the R/T is 6" and the chuck is 5". I'll make it work.
Do you think it would be worthwhile to buy new jaws for that ol' Buck chuck?
I realize it still would need to be ground but wouldn't this be a bit more help to tighten it up?
Thanks!
Top
 Profile
 Post subject:
PostPosted: Fri Dec 16, 2005 2:47 am
I put my jaws up on the surface grinder (individually) , clean up the low jaw first (high indicator reading on the stock), and grind the others individually to true up the chuck.
You can expect to replace the jaws in the chuck and re-indicate several times to get it done.
This was done once when the new chuck came in.
I can taper the back of the jaws a couple thou more to get full legnth gripping power this way.
On the other lathe, the locating diameter is .01 loose allowing me to indicate individual jobs true without cutting anything.
Different ways of doing things.
Kap
Top
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Localized by Maël Soucaze © 2010 phpBB.fr
