I've been working on a backplate to use with what is going to be a dedicated soft jaw chuck (Harold's made me a convert).
I read all the prior posts on machining a backplate and wrote out all the steps I needed to to. Really helps to have a plan.
Harold's been giving me some help on this, and I've been taking pictures along the way, so he suggested that I share it with the group.
The backplate, which I bought from
www.littlemachineshop.com for $30, comes machined and threaded. The rear surface is machined, but I'm not going to rely that it is perpendicular to the bore.
The existing 4-jaw and 3-jaw are about 7 thou larger than the spindle nose, and therefore, they are using the threads for location. We will shoot for having the bore locate the backplate.
The spindle is threaded 1-1/2x8 tpi and is threaded only part way down. The rest of it is available to register the backplate (about 0.2"). The spindle has a shoulder, but it is almost the same size as the rear of the backplate, so I will not use that to locate the backplate to the spindle. The rear of the backplate needs to be bored out to sufficient depth to fit over the unthreaded portion (including the portion where the thread gradually ends). The 4-jaw is unthreaded for about 3/8".
I made a plug gauge the exact diameter of the spindle. I did not make a complete clone of the spindle, although it is a good thing to have and I probably should at some point.
The backplate is deeper than I need, so to reduce overhang, I decides to machine off 1/4" off the rear. Prior to removing this material, I practiced machining the bore and getting it to the size of the plug gauge. Once I was comfortable with getting the fit right, I marked off 1/4" using calipers to mark it and took the off 1/4" off the rear.
To bore the back, I need to set the backplate out from the spindle, so I would need some kind of precision washer or spacer to hold it accurately. I bought a 1-1/2" milling machine arbor spacer. I got one 1/2" thick, as I needed some extra room to machine off the 1/4" from the back. I checked the spacer and found that there was a high spot, but the spindle had a high spot as well (no, I don't have the nerve to machine the spindle at this point). The amounts we are taling about are 1 thou or less. I mounted the adaptor to the spindle in the location that cancelled these out as much as possible.
To machine the inside of the bore, I used a small, round nose HSS boring tool. To face off the rear, I used a roughing tool with no rake, but a chip breaker. It gave a somewhat rough (fuzzy) finish.
I used a large radius round-nose tool with zero rake and power cross feed to finish and got a really good surface finish. I will use this tool to do the final work on the backplate. I do not have any C2 carbide, so we will be sticking to HSS.
Once I was done, I used a file to take off the rough corner on the outside and a 45 degree tool to chamfer the inside edge.
I've included a picture of some of the tools I used.
