Now that the face is finished, I need to locate the 6 bolt holes. The bolt circle is 5-1/2". I used a pointed tool in the toolpost to scribe the circle. First, I needed to line the tool up and zero the cross slide.
Then I backed the cross slide up one-half the bolt circle diameter and scribed the circle. Of course, I forgot about the 1/2", and did it wrong. I set the cross-slide up again and marked the circle. I checked the circle with dividers set to 5-1/2.
Next, I needed to mark off where the bolt holes go. A 6-hole layout is actually easy, as you can just set a caliper to the radius and use that to mark from one hole to the next, as the radius is equal to the chord between each hole.
Instead, I chose to use something I never thought I would have a use for when I got my lathe: an indexing pin. The Atlas has 60 holes in the bull gear, and a pin that holds the bull gear locked on one of the holes.
To be sure I didn't screw up anything if I forgot to release the pin and turned the lathe on, I unplugged the lathe and released the bull gear from the spindle (as you would in backgear). This also made it easier to turn the spindle.
I used the pointed tool to make a mark on the circle by moving it back and forth. Then I counted out 10 holes and did it again. I repeated this until I got back to the original mark (whew!). You can see some of the marks in the picture. I checked the marks with calipers set to the radius.
Next, I will center punch and drill the holes. Then I need to counterbore from the rear for the socket head cap screws.
| Attachments: |
