The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Sat Jul 31, 2010 1:12 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Thanks Harold, Trued another 3-Jaw
PostPosted: Sun Mar 18, 2007 4:13 pm
Offline
Well I trued up the jaws on the 3-jaw chuck that came withe South Bend I recently bought. The information I learned from Harold V the last time in this thread: http://www.chaski.org/homemachinist/vie ... jaw+chucks came in handy once again.
This time the results were even better, .001" TIR, hope I can keep it that way :D .
Ernie F.
Top
 Profile
 Post subject:
PostPosted: Mon Mar 19, 2007 11:10 am
Offline
Ernie,
What did you use for a grinder?
Can you post a picture?
Top
 Profile
 Post subject: Re: Thanks Harold, Trued another 3-Jaw
PostPosted: Mon Mar 19, 2007 2:39 pm
Offline
Ernie F.
That's pretty impressive, Ernie. Have you checked the chuck over a range of sizes? You can usually expect the runout to vary as you do---so if yours doesn't, you have a scroll that is well centered and very round.
You deserve the credit, Ernie. You did the work. Sadly, others may not enjoy your level of achievement---in spite of having read the same information.
Top
 Profile
PostPosted: Mon Mar 19, 2007 10:11 pm
Offline
I didn't take any photos but used the same air die grinder in a photo on the other thread, (use the link I posted). I stone is about 1" diameter, 60 grit if I remember. What I did different this time was to clamp the die grinder to the side of a 4 way tool post instead of the Rube Goldberg I used the last time. That was a shorter, more solid set up with less (no?)flex. I spent a lot of time matching the heights of the jaws on the deep end and a lot of time making sure the slug was square in the chuck prior to grinding. I also set up a stop to keep the grinder from crashing into the slug. Many light cut passes with the stone, and even lighter near the end until almost no sparks.
Harold_V wrote:
Have you checked the chuck over a range of sizes? You can usually expect the run out to vary as you do---so if yours doesn't, you have a scroll that is well centered and very round.
I ground the chuck with a slug approximately 1.5" and checked with a short length of round stock about the same size but turned round. There it is .001" run out. From there I went to some 5/8" cold rolled for a project and it was .002". All new metal stock is suspect to me, and sometimes I can visually see improvements by rotating and trying different positions in the chuck.
It's still a three jaw and I will treat it as such, too many reasons for them not be perfect (if there is such a thing) but somewhere under .003" is something i can work with. The old chuck was loping like a camshaft at around .010" TIR.
Regrinding sure beats a few hundred for a new chuck and all the work to set it up. I noticed new chucks are advertised with various degrees of run out, less run out = more $.
Ernie F.
Top
 Profile
 Post subject:
PostPosted: Tue Mar 20, 2007 7:13 am
Offline
Thanks, Ernie.
My 3-jaw has a problem with the front of the jaws visibly more worn than the rear, so regrinding is on my list of things to do.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google [Bot] and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
