The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Sat Jul 31, 2010 1:13 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: 4 X 6 bar feeder
PostPosted: Sat Sep 27, 2008 6:08 am
Offline
I was running my homebuilt barfeeder yesterday and remembered I never made a digital video of the barfeeder running. Now that I have a camera that also takes videos I'm building a library of my automation projects actually running.
The barfeeder is controlled with an Allen-Bradely Micrologix 1000 PLC.
The air cylinders are actuated by SMC air valves. The barfeeder runs a little slow because the air valves are undersize. However, the slow speeds make for a smooth running barfeeder with accurate feed lengths.
Not much chance of overfeeding or underfeeding at these speeds.
The saw and barfeeder. Eight years old and still going:
http://img.photobucket.com/albums/v30/j ... eeder6.jpg
The feed clamps:
http://smg.photobucket.com/albums/v30/j ... eedend.flv
The drop end:
http://smg.photobucket.com/albums/v30/j ... ropend.flv
In case someone is wondering the Kant-Twist-Clamp is clamping a white plastic block holds the bar stock down. Sometimes the barstock wants to creep upward without the retaining block.
Hope this was of interest,
Jim
_________________
www.outbackmachineshop.com
Top
 Profile
 Post subject:
PostPosted: Sat Sep 27, 2008 10:12 am
Offline
wow, sure is to me Jim.
I have a punch press to set up and I was wondering about an autofeed of some sort.
Because of expense, I was leaning toward ice cube relay logic for function. Key motion, sense,(feedback) next motion, trip, etc to reset/replay. a missed sense would stall operation.
I dont know how expensive plc controllers are, probably way past my wallet, but I am thinking of the future as I have no need at the moment.
_________________
Big Dave
Top
 Profile
 Post subject:
PostPosted: Sat Sep 27, 2008 10:31 am
Offline
Dave:
I buy Mircrologic PLC'S on Ebay all the time for around $100. The software is expensive and there is a learning curve. There are tons of other PLC's on the market. But, I have the software and twelve years of experience with Allen-Bradely PLC's so that is why I use them. The program used to run the barfeeder will come very close to running a strip feeder for a punch press. I have used the same program for several jobs that require a feed advance. A little tweeking for each application.
However, for small strips of metal there are strip feeders that run on compressed air all ready to go. The punchpress hits a button on the feeder to initiate the feed advance. I have seen those on Ebay for
$25 to $50. Those feeders have a name that I cannot remember this morning. Ah, I just remembered, "Rapid Air".
Jim
_________________
Top
 Profile
 Post subject: Allen bradly
PostPosted: Sat Sep 27, 2008 1:43 pm
Offline
Ya, mostly Allen Bradley for me, but they were magic boxes, mostly looked at the logic ladder to find what was missing, as most failures were in field controls or wiring, not the controller. So I dont have much experience in setup, that will be new ground for me.
The strip feeders I have seen were much more expensive, and I am not aware of micro logic, so you have advanced me several light years here. thanks.
Many processes can be done on a press, bend, form, shear, with spot, or progressive handling. Most often depends on the press tonnage. With the mechanical press I have, I thought of doing small sheet forming work. A hydraulic press can be VERY handy for the home guy that needs to bendstuff, and forms for low production or general one-offs are easy to concoct. I gave 75 bucks for a 12 tonner, I am happy.
_________________
Big Dave
Top
 Profile
 Post subject:
PostPosted: Sat Sep 27, 2008 10:34 pm
Offline
Hi all. Another option for controlling a saw like Jims, is a (smart relay). Its basically a small plc but way cheaper and software is included. The basic units can handle about 20 lines of logic. IDEC is one brand, most of the plc providers are puttin gthese out now. doa google search for more...
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google Adsense [Bot], Yahoo [Bot] and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
