Calculating compound angle for taper bore
korndog
Post by korndog » Sat Jan 15, 2011 4:23 pm
Say
I have been trying to find a calculator to do this online but have had no luck. I need to go from 30mm to 27mm over a 50.65mm length of tubing.
Any help would be appreciated.
KD
Re: Calculating compound angle for taper bore
Post by GlennW » Sat Jan 15, 2011 5:01 pm
How about a re-print from a previous question...
Glenn Wegman wrote:So,
75mm long
large end=12mm
small end=4mm
Large end - small end= diameter change. 12-4=8
Since the taper attachment only wants to know the half angle, divide that by 2. 8/2=4
The half angle change would be 4mm in 75mm.
The angle in decimal degrees would be found using: atan=(height/length) or atan=(4/75) which is atan .0533 which is 3.0528°
Now to convert decimal degrees to degrees, munutes, seconds:
3° is the degree, which leaves .0528° to be converted into minutes.
Multiply .0528 by 60. .0528 x 60= 3.168. Which 3 would be the minutes, so we now have 3° 3'.
Now multiple the remaining .168 by 60: .168 x 60= 10.08. Which 10 now becomes seconds, so we now have 3° 3' 10".
I'm pretty sure someone that knows something about trigonometry (definitely not me) can show a simpler way to do it, but that is one way to do it since you have a taper attachment and will most likely need to do it again!
Rick
Post by Rick » Sat Jan 15, 2011 5:09 pm
This is the angle per side or what to set the taper / compound to
Tan = rise/run 0r opposite/adjacent
Rise =(30-27)/2
run =50.65
tan (angle)= ((30-27)/2)/ 50.65
angle =atan (1.5/50.65)
ANGLE= 1.696 DEGREES
Rick
korndog
Post by korndog » Sun Jan 16, 2011 12:00 am
Rick wrote:This is the angle per side or what to set the taper / compound to
Rise =(30-27)/2
run =50.65
excellent post...Thank you. Simple, direct, educational.
