Floating Reamer Holder.
Moderators: JackF, Harold_V
AllenH59
Post by AllenH59 »
Gentlemen....
I have not chambered a barrel before, and am going to cut my teeth cutting Improved chambers in a couple bubba'd 6.5x55's. I have bought a reamer and a GO gauge, and and alignment rod and a set of pilots to align the barrel. I have the required measuring tools and will have no problem setting the barrel back a thread and headspacing.. My question concerns my particular lathe.. There is just about no room to make a spider for the outboard end of the spindle, and it is 27" from the face of the 4 jaw to the outboard end of the spindle. This means that I will be working with the steady rest to do the setting back, threading and chambering. My lathe will take 48" between centers, so I am not short of room. I put the heart of a vernier caliper on the tailstock to make a DRO on that. My question concerns using a Floating Reamer Holder. There is no rush for this work, and I will happily build one. I have read comments both ways considering the use of them. What do you guys think. Do you think in my situation this would benefit me? My goal after I have a bit of confidence chambering is to install new barrels, and contour them to shape. I am not intimidated by the external work at all, I just want to have a good system to confidently cut accurate chambers. Thanks.
earlgo
Re: Floating Reamer Holder.
Post by earlgo »
When I was at the Colorado School of Trades, we chambered a lot of barrels. That was nearly 50 years ago and I can't remember if we used a floating reamer holder or not. However, having said that, I do own a FRH so I must have gotten the idea somewhere.
If you use a steady rest instead of a 4 jaw chuck, then you will have no way to compensate if the chamber is not concentric with the OD of the barrel riding in the steady rest. A FRH is then mandatory. Brownell's Gunsmith Kinks books recommend a FRH also.
Be aware if you try to ream a hole that is not rotating coaxially with the reamer, you will not get what you hoped for whether you use a straight reamer or chambering reamer. When reaming, you will also have to pull the reamer at short intervals and flood the reamer to get rid of chips. There is nothing like a nice smooth chamber with a ring in it, to make you invent new Anglo-Saxon invectives.
I recommend you do some reading on this subject and practicing on inexpensive barrels before you chamber the friend's Weatherby. :lol:
--earlgo
johnfreese
Post by johnfreese »
You can often find used Glenzer or Scully Jones floating holders on the Bay. Both offer radial float but no angular float. A no.2 taper tap driver for a 1/8" pipe tap will drive the reamer. Instead of grinding the flats on the reamer to fit the square in the tap driver I just grip the reamer on the round shank by friction. That allows the reamer to spin in the driver before anything breaks.
One os the reamer manufacturers sells a floating reamer loosely based on the Glenzer. In my opinion these are the only floating holders worth owning.
seagiant1
Post by seagiant1 »
Hi,
I just built a FRH, a Bald Eagle type.
Easy to make, ordered a Chi-Com MT2 blank to fit the tailstock of lathe, and...
Machined everything else needed.
Beats paying $100 for one.
https://duckduckgo.com/?t=ffab&q=bald+e ... 542929.jpg
Rolland
Post by Rolland »
might spend some time and watch this guys video he has some other videos that are good to watch regarding chambering.
https://www.youtube.com/watch?v=xNhZnpSrMVA
