Flux Core fumes
Moderators: Harold_V, Scott
tornitore45
Flux Core fumes
Post by tornitore45 » Sun Sep 13, 2020 6:50 pm
I have a cheap crappy $100 Flux Core Wire welder for Harbor Freight, however I suspect it could do a better job in the hand of somebody that knows what is doing.
Any way whatever is in the core splatters and fumes. How toxic are those fumes? I learned the hard way how bad Silver brazing can be.
Mauro Gaetano
in Austin TX
Russ Hanscom
Re: Flux Core fumes
Post by Russ Hanscom » Sun Sep 13, 2020 8:02 pm
Might look at the MSDS (material safety data sheet) for the wire you are using. It will emphasize the worst issues.
Any welding should be done in a well ventilated area, just in case.
Re: Flux Core fumes
Post by Harold_V » Mon Sep 14, 2020 1:04 am
Wow! That can prove deadly! Cadmium is used to control oxidation of the copper in (some) silver solder. It is a known killer.
Could you please provide some details of your experience?
liveaboard
Re: Flux Core fumes
Post by liveaboard » Mon Sep 14, 2020 4:07 am
I poisoned myself stick welding [indoors] the other day. I had a headache and burning lungs.
Fume hood or weld outside.
But don't start any fires!
I find a bucket of water to be effective for dousing small incendiary events.
tornitore45
Re: Flux Core fumes
Post by tornitore45 » Mon Sep 14, 2020 2:39 pm
I was doing 5 or 6 small jobs that did not need prolonged heating so I did not bother to set up outside. After the 3rd or 4th job I felt progressively a stomach ache that became worst even after I quit. I also felt a bit hazy. I looked up the symptoms and based on that I thought that drinking water was possibly beneficial. The therapy is gastric flush so I though drinking was the closest thing I could do on the spot. It took about 20 minutes to start feel better.
My original post was stupid anyway, I should know better that that kind of work should be done outside with ventilation.
Mauro Gaetano
in Austin TX
Re: Flux Core fumes
Post by Harold_V » Mon Sep 14, 2020 2:50 pm
Thanks.
When I designed my shop, I included a large ventilation fan above the weld table, one with automatic louvers. An opposing window (opposite wall) allows for good air movement, so I can weld or braze inside without worry. The fan has proven to be a good idea, as I use it to remove fumes from the use of sulfur based cutting oils, too. I simply open the appropriate window, be it mill or lathe work, and run the fan.
John Hasler
Re: Flux Core fumes
Post by John Hasler » Wed Sep 16, 2020 10:41 am
The symptoms of acute[1] cadmium poisoning are respiratory, not gastric. Basically, metal fume fever. It is most hazardous as a long term cumulative poison, though.
[1] "Acute" in this context means immediate, not severe.
Eoinfork
Re: Flux Core fumes
Post by Eoinfork » Tue Dec 01, 2020 8:29 am
MSDS are good option
