Page 1 of 1
Welding Positioner
Posted: Fri Feb 22, 2019 9:14 pm
by armscor 1
Need to build up a shaft with weld.
Built this.
Re: Welding Positioner
Posted: Sat Feb 23, 2019 3:44 am
by liveaboard
We'll need to see that in action!
Posted: Sat Feb 23, 2019 9:34 am
by Russ Hanscom
Ingenious, just don't that with a good chuck! I see you have the ground as close to the work as possible.
Posted: Sat Feb 23, 2019 3:49 pm
by armscor 1
Yep, no possibility of welding spindle bearings.
Made a 98 tooth gear to give me the speed reduction, goes down to just under 1 rpm.
The mill power feed was removed from my mill and I upgraded to an Align to give me higher rapid speed.
Going to make a slotted faceplate that will grip in the 3 jaw chuck to give me more versatility.
Posted: Sun Feb 24, 2019 3:43 pm
by armscor 1
Tested at 140 amps, no interruption to current, slip ring holds up, very happy.
Posted: Fri May 10, 2019 11:22 am
by fonzy
Cool build. I just retired and recently posted a few videos on YouTube. This one has a turntable I built from a junk 7" grinder, and a foot operated one. Can be seen at:
https://www.youtube.com/watch?v=l4je9lowQj4
Please like, comment, and subscribe to my channel. Al
