Page 2 of 2
Re: Flux Core fumes
Posted: Mon Mar 22, 2021 5:41 am
by Kay_B
Yes, any technical vapors are harmful and it is best to work in a respirator if you do not work outdoors. In the room, a respirator is required, and until you ventilate the room, it is better not to take off the respirator.
Re: Flux Core fumes
Posted: Mon Mar 22, 2021 6:28 pm
by liveaboard
heislerboy wrote: ↑Fri Mar 19, 2021 3:57 pm
you can't use stick welding in a typhoon, the max wind speed to weld in is 5 miles per hour this is from AWS (American Weld Society)
Andrew
Welding in light wind works fine in practice, certainly more than 5mph.
However, when the wind gets really strong it will blow the ark right off the work.
I got no certification, but I did a lot of welding (a kilometer) out in the weather.
Re: Flux Core fumes
Posted: Thu Mar 25, 2021 6:07 pm
by Russ Hanscom
Exterior welders use shields or shelters for wind protection. It does not take much wind, just a breeze, to cause unacceptable defects in stick welds. The x-ray man will tell you, and repairs are expensive.
