Then hand him the stinger and tell him to "show you". All too often, many, even experienced welders, think they need to completely tie the joint - when structurally speaking, there is no benefit or logical reason to do so. The more heat you apply to a joint, the greater the propensity for distortion. Yes, sometimes there is valid reason(s) to run a single, continuous bead, but preventative measures MUST be in place to avoid distortion and unwanted movement.Phil3 wrote:It was suggested to me to actually use one long bead, that there is some disadvantage to starting and stopping along one long bead.
Just think about all the assemblies that are 'bolted' together... 'Tis nothing more than a large tack (spot) weld in the center of the pieces.
