I am in the process of rebuilding my Prest-O-Lite Acetylene (originally Union Carbide) torch. It’s 60 or so years old, inherited from my Dad. The o-rings in the valves have all hardened and the 401 handle leaks gas around the valve stem. I have ordered the proper o-rings from WeldingSupply.com as per the original instructions/parts list from Prest-O-Lite. I tried o-rings from a kit from HF with no joy.
My question, should I use some type of lube on the new o-rings when I install them?
Chuck
Presto-Lite torch rebuild
- warmstrong1955
Re: Presto-Lite torch rebuild
Absolutely not!
Oil + Oxygen = 'poof'
Chuck,chucketn wrote:I am in the process of rebuilding my Prest-O-Lite Acetylene (originally Union Carbide) torch. It’s 60 or so years old, inherited from my Dad. The o-rings in the valves have all hardened and the 401 handle leaks gas around the valve stem. I have ordered the proper o-rings from WeldingSupply.com as per the original instructions/parts list from Prest-O-Lite. I tried o-rings from a kit from HF with no joy.
Chuck
Oil and/or Grease are a BIG NO
Please see the SAFETY info below.
These might load a little slow..
http://www.usmra.com/repository/categor ... tylene.ppt
http://www.airgas.com/documents/pdf/001001.pdf
Ken.
One must remember.
Ken.
Ken.
This is an acetylene/air torch, not Ox/Acet.
Would silicon grease be o.k.?
Chuck
Chuck
- warmstrong1955
The big problem is any oils or grease around oxygen.....but I still would not use any oils or greases on any compressed gas. I don't use it on inert gases either....would it make the o-rings last longer....maybe.... but it's just a NO-NO. O-Rings are cheap.chucketn wrote:This is an acetylene/air torch, not Ox/Acet.
Chuck
I really don't know if acetylene is reactive with silicone grease or not. Not something I would experiment with.
Again. O-Rings are cheap.
i would check this out in detail
there is a selection of greases that do not contain any hydrocarbons.
The stuff is called PFPE for poly-fluorinated-poly-ether.
The related oils are marketed as FOMBLIN or KRYTOX. (used in pumps that pump oxygen)
The grease (in USA) is marketed as Braycote by Castrol. I am sure that it is suited for your application.
Have success.
having said that i would resurch the brand names before aplication.
for my personal 2 cents i want everything dry.
Have success.
chuck,
Here you Go.
OC® Three – Oxygen Compatible PTFE Paste (Includes Acetylene)
http://www.mptindustries.com/oc_products/oc3.htm
Ken.
Here you Go.
Ken.
One must remember.
Ken.
Ken.
