Cutting thin sheet metal
Re: Cutting thin sheet metal
If you take a piece of plywood or MDF and cut your holes in it with the mill, It will work as your top hold-down, and act as a pattern for your mill to follow…..saves time in the layout, and holds the material tight to the lower table so no slippage, nor will it allow the material to rise when being milled.
