Question about what sliprolls will do
Moderators: Harold_V, GlennW
gwrdriver
Post by gwrdriver » Mon Mar 22, 2004 5:43 pm
I have an 12" long piece of 6" copper pipe (.140" wall) which needs to be turned (using a fixed steady rest). This was cut from the end of a long tube and I discovered that at some point the full tube was dropped (or maybe just bumped) and there is a shallow flat area on one end making that end sort of egg-shaped. If this tube is put through a few turns in a sliproll will they take out that flat and return the tube to reasonably round?
GWRdriver
Nashville TN
Jacin
Re: Question about what sliprolls will do
Post by Jacin » Mon Mar 22, 2004 6:11 pm
I would go ahead and just try it - thinking you sure can't hurt it much. I would consider annealing it if it doesn't work the first time. If that doesn't work you might consider cold working it on a shot bag to get the majority of it in the right place and then fine tune it on a slip roll.
Then of course there's always the SPINNING approach!!!! That's some WILD stuff - I've done a wee tiny bit of that and it's just plain cool to watch!!
Let us know!!! [img]/ubb/images/graemlins/grin.gif"%20alt="[/img]
Ralph_Monroe_Mi
Post by Ralph_Monroe_Mi » Tue Mar 23, 2004 8:54 am
You might also try turning a piece of hardwood or delrin to the the id of the tube and pressing it thru. It should probably be a couple inches thick to prevent cocking, so you can screw several pieces together. A little lead will ease the way.
Ralph
