Lead Ball Mold
ctwo
Lead Ball Mold
Post by ctwo » Thu Jan 07, 2021 12:19 am
Hey, this seems like a good first dip...
Once I thought I'd get into skeet shooting, then they banned all my clay birds, then they banned lead shot, so now I figure I will convert all of my #7-1/2 bird to #3 buck. I'll make the other side #000 or something interesting.
These would be 1/4" balls and the connecty thing (sprue?) was drilled 1/16". I heated the mold on the gas stove to as hot as it would get. It does not get hot enough to melt the failed pour. The lead was heated in a tin can on the stove as well, and would have to be poured quickly or it freezes on the way out.
Will this leak if I use a propane torch to melt it in place? The surfaces are lapped and the blocks clamped. Is it making an airlock? What do I need to do?
10KPete
Re: Lead Ball Mold
Post by 10KPete » Thu Jan 07, 2021 2:36 am
Yes, there are no vents. The faces of the blocks should be scored minimum of .02" deep and same width. A simple V. Score 2 horizontally across each cavity all the way across the block face. Then the same vertically across each cavity. This gives 8 vent entries into each cavity.
Lyman has always vented the faces of their mould blocks before the last cherry and final lap.
I figure if they do it, I'd be a fool not to try it. That was 50 years ago and I haven't looked back.
I don't recommend heating the block very much. Just enough to hasten the production of a good surface on the balls. Then your casting speed will adjust the just right temp as you continue.
Pete
Just tryin'
Re: Lead Ball Mold
Post by Harold_V » Thu Jan 07, 2021 4:42 pm
My opinion, having built a similar mold many, many years ago. Mine made 9/32" diameter balls, which allowed for three balls/layer for a 20 gauge shotgun. They turned out beautifully, and I still have the mold, although I don't use it these days. Of interest, perhaps, the mold was the first thing made on a Gorton 8½D mill after it was completely rebuilt (inhouse). Not so much as a DRO was used----all done by the screws with excellent results.
It is highly unlikely that you'll enjoy success with that design, although I could be wrong. Here's why.
In order for the bottom ball to fill, the lead must remain molten through the upper balls. Not much of a chance of that happening due to the 1/16" sprue. They're an acceptable size, but not for feeding more than one ball.
My mold pours multiple balls (two per layer), one on each side of a center runner that is (I think) 3/16" diameter. It runs the long way through the mold (top to bottom), and provides a stream of molten alloy to the bottom, so each ball fills independent of the others. I also have vents, although I do not recall the details. My mold is built to mount to Lyman handles.
I'm not suggesting that my way is the only way, but I can assure you that it works.
If it's important for you to see a picture, I can provide one, but I do not have one available right now or It would have been posted. If I do that, I'll also provide better detail of the mold features. Let me know.
FKreider
Re: Lead Ball Mold
Post by FKreider » Thu Jan 07, 2021 4:55 pm
Always need a vent.
-Frank K.
ctwo
Re: Lead Ball Mold
Post by ctwo » Fri Jan 08, 2021 1:52 am
Thanks All. This was trying to be like a Lee buckshot mold. I noticed they do have grooves so I'll give that a try. I also think that using a tin can allowed the lead to cool too much on the way out, so something heavier may also help.
Jon W
Re: Lead Ball Mold
Post by Jon W » Fri Jan 08, 2021 7:54 am
For whatever it’s worth, graphite crucibles are available on Amazon for fairly short money.
Jon W
Somewhere North of Boston
