Metal casting is something that interests me, but there is no room for another activity in my life. I've lucked into the next best thing. I took a mechanic position in an iron foundry last September.
The company was established in the mid 1800's at the present location.
The picture is the charging of a 50 ton capacity induction furnace. The iron is being dumped into the furnace much faster than normal to work at clearing the throat - the area around the induction coil which is located near the bottom. The iron needs to circulate around the coil by convection. I happened to be working in the area, and of course missed some more spectacular shots.
Charging a Furnace
Charging a Furnace
BC
If there was only one way to do each machining job, the smell of sulphurized cutting oil smoke would have fewer fond memories.
