I am building a monster burner using plans via the web. 2" reducer to 1 1/4" pipe that is 12" long. I have a small 5 gallon propane tank and am not planning on using a blower.
I am designing the gas orifice so I can screw in a Tweco welding tip. Does anyone have an idea of the correct tip? I have .023", .030, and .035" tips that I use with my welder. Will any of these work?
Monster Burner
Hi,gangel99 wrote: Does anyone have an idea of the correct tip? I have .023", .030, and .035" tips that I use with my welder. Will any of these work?
You can experiment with any of the three sizes you have. My guess is that each will work. Select the one that gives you the most efficient flame
On my reil-style burner, I simply drilled a few different sized holes and settled with using the one that gave me a nice blue flame, and didnt flashback.
I made a forge with two non-blown burners. I use Tweco .035 tips, and a regulator that is adjustable from .5 to 45 psi. The burners are completely stable throughout that pressure range. If you're planning on using a barbecue regulator, it won't work. If you're planning on using a single 20lb cylinder, that won't work well either. A big burner boils off enough gas to freeze a small cylinder in just a few minutes, reducing the pressure to almost nothing in cooler weather. (You might be OK in the summer sun). I use two 20lb tanks in parallel and still have trouble in ambient temps below 50 deg F.
It is also necessary to remove the flow-limiter from the tank connector.
Be sure to make the location of your gas jet adjustable, and pay particular attention to the internal taper of your burner nozzle. The gas jet postion is sensitive to 1/16 of an inch in a 2" tube, and without the proper nozzle taper your flame will not be stable at a wide range of pressures.
Gordon
OOPS! my first visit to this forum, and I just noticed the last post was last year. Oh well, maybe it'll help somebody sometime!
Gordon
- steamin10
My homebult furnace has 100lb tank feeding it with a Gas regualtor and torch hosing. Turning up the reg gives more gas pressure and feed at the nozzle and the flame is really good. I only run aluminum in this furnace, and use the other blown furnace for Bronzes.
If you do diferent metals, use a diferent crucible for each metal. I use and iron dutch oven for lead and pewter like metals.
Local fill station inspects my tank, and sells lp by the lb across a scale. Not too bad. They service campers and mobile homes, so prices are fair.
