furnace
Charles Cleland
furnace
Post by Charles Cleland »
________________________________________
When I going to central trade school in 1944 there was a natural gas furnace that looked like a blower going into a box shaped stack of fire bricks .It was used for heat treating & forging. I would like to build one .Has anyone had any like ideas?
chaz
_________________
Still hanging in there
chaz
chaz
LarryM
Post by LarryM »
Here are some picture of a, propane fired, firebrick forge I built last winter. No blower needed on this type of burner. I made the burner from 3/4", 1",and 2" pipe. It uses a .030 MIG welding tip for the orfice. The wing bolt on the side is an air coke to ajust fuel/air mixture. As you can see plenty of heat to forge or heat treat.
Fire brick forge
Here is a website that will show you how to build this type forge.
Zoeller forge.com
Have fun playing with this one!!!
Larry
Try not to spend $10.00 worth of time on a $.10 job!
Charles Cleland
Thanks Larry I have already checked out your burner and it may be just thing with plenty of btu's to spare but I have my heart set on natrual gas as all my other stuff runs on natrual gas and it is cheap.let's see if we get any more replys Mabe one of you guys have seen what I have in mind.
chaz
chaz
