Vacuum Pump Oil
atlantic442
Vacuum Pump Oil
Post by atlantic442 » Mon Apr 05, 2010 10:45 pm
Anybody know what kind of oil is used in vacuum pumps. The coupling between the motor and the pump on my table top unit fell apart. So, as long as it apart I thought I should change the oil.
Hans
david5605
Post by david5605 » Tue Apr 06, 2010 1:47 pm
http://www.amazon.com/Vacuum-Pump-Oil-Q ... B000X1E59S
:D
All kinds of google hits for vacuum pump oil.
gustavus
Re: Vacuum Pump Oil
Post by gustavus » Sun Apr 18, 2010 1:59 am
atlantic442 wrote:Anybody know what kind of oil is used in vacuum pumps. The coupling between the motor and the pump on my table top unit fell apart. So, as long as it apart I thought I should change the oil.
Hans
Any non detergent oil will work, hydraulic or ATF
www.chaski.com
steamin10
Re: Vacuum Pump Oil
Post by steamin10 » Sun Apr 18, 2010 11:44 am
any oil: TRUE, if you are not handling refrigerants. If you are you need to go to a HVAC supply house and get a bottle of pump oil. It is changed often around refrigerant handling equipment because of the effects of small moisture and the Flourine, and Chlorine created acids.
atlantic442
Re: Vacuum Pump Oil
Post by atlantic442 » Sun Apr 18, 2010 1:10 pm
Thank you gentlemen, I went to a local HVAC contractor told him what I was doing and he donated a quart to the cause. With the situlation that I return with samples for show and tell.
Hans
