Pyrometer
Wanna-Be
Pyrometer
Post by Wanna-Be » Tue Apr 20, 2010 10:28 am
I'm new to this but recognize I'm going to need a pyrometer to monitor the furnace temp..
I plan to use my McEnglevan gas furnace for casting aluminum to gray cast iron, as well as heat treating.
I have seen sensors that can be plugged into a Fluke multi meter but no sure of their range, etc..
Any advice would be appreciated.
Jet vert Mill, Champion 12X30 lathe, Amer. Mach. Tool radial drill, 24X60 LeBlond lathe, Scharmann 3" Hrz Brg Mill, Steptoe 18" Shaper, S/B Shaper,B&S (No.4 36") Gear Cutting Mach., Verson 22.5T Press Brake, Enco 12" hrz. saw, McEnglevan foundry furnace, Rockwell 14X42 lathe, K&T 2H univ horz. mill,DoAll 16-2 Vrt. bandsaw,Canedy-Otto drill press,Buffalo Iron Worker
Re: Pyrometer
Post by SteveM » Tue Apr 20, 2010 1:13 pm
I can't help, but I know these guys can:
http://www.omega.com/
Just about everything for measuring temperature, pressure, humidity and other environmental variables.
