Moulding flasks
Posted: Sun Oct 03, 2010 3:46 am
Hi All .
This is my first post here ,, i apologize if there are too many photos ,,,, i am not the best with words
One thing has always bugged me about my foundry set up and that was the moulding flasks made from wood ,, they burn when you spill molten metal on them , warp and generally fall to bits after a wile ,,,,,,,,,, so time for some steel flasks ,, last week i had eight lengths of 1/8" x 4" steel given ,, all about 110" long ,,,,,,, just the job me thinks to make some flasks from .
Then i thought i need a bead up the lengths of steel ,so that the sand would grip to , as this it a one off job i knocked up a ruff and ready press tool from bit of off cuts .
dragged my shop built press into the middle of the shop and fed the lengths of steel through the press 6" at a time
When all were done ,, they were cut into 65" lengths , then all the off cuts were welded together and cut to 65" ,, this gave me enough for 6 set of flasks 12"x16".
next came the bending ,, so i removed the large vice from my welding bench and tac welded 4 lengths of round bar to it , for the bending jig .
The lengths were then bent round the jig ,heating the bends with oxy gear
Then after they were all bent up , the over lap was trimmed off and welded up
Due to the welding and bending they had a bit of a warp in them .
easy fix , stuck a shim under the one of the high corners , this is to allow for the bit spring back ,
plonk a bit weight on the offending corners , and heat the other to .
Next was to make sure they are truly flat , as some metal on the corners get raised due to hammering on the bends , a bit grinding took care of that using one of my ally core plates as a reference.
Then they were paired up ,cos they aint all the same ,,,,,,,,,,, the ones i did with a hangover are slightly different
Made the handles from some re-bar i had scrounged ,, nice and grippy ,, my #25 vice was just the job to use as a bending jig ,,,,, heat, bend , bash
Then the pins and handles were then welded to the flasks , using the mark one eye ball and my least squished thumb to get them in ruffly the right place
They still need a bit of tweaking here and there ,,,,,,,,,, nowt to major ,,,,,,,,,,,, well that's another job off the list .
Rob
Rob
