Is there a way to search the Memberlist alphabetically without having to go page by page from either end?
David
Memberlist
Moderators: Harold_V, Marty_Escarcega
Re: Memberlist
Select sort method: Username Order: Ascendingsrrl5 wrote:Is there a way to search the Memberlist alphabetically without having to go page by page from either end?
David
- willjordan
Re: Memberlist
If you start with the Alpha sort, the link to the last page, page 76 issrrl5 wrote:Is there a way to search the Memberlist alphabetically without having to go page by page from either end?
David
http://www.chaski.org/homemachinist/mem ... start=3750
If you want to hit the middle of the list, edit the link to
http://www.chaski.org/homemachinist/mem ... start=1875
and so forth.
It's not so quick as if there was an alpha index, but will get you there a lot faster than paging. On my system, I've set the default to 50 lines per screen, you might want to see if you can set that for a higher number.
grace & peace
will
[url=http://willjordan.com]Will's Web Pages[/url]
will
