Marty,
I keep getting an IE script error with every page.
says Line 6
char. 4
error - object required.
Is it my end or yours????
Thanks, Bill
IE Script error
Moderators: Harold_V, Marty_Escarcega
ERRORS
I don't see it. You may need to have Java Script files loaded on your pc to work with IE. I think under the Tools option you can check them.
U may have to go to Sun systems and down load also. Just a thought.
tom_at_srclry_com
A student of the Southend RGS!
I was also getting the script errors. I turned JavaScript error reporting off to get rid of them. A week or two ago, I switched to the Alexis v1.2 theme because I like it better than the default. Two days ago I turned JavaScript error reporting on to work on a web page. I forgot to turn it back off before coming back here but haven't had any script errors so I think the error may be in the default theme. You might try switching to the Alexis theme to see if that makes the errors go away.
