3" sine vise
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
SteveM
3" sine vise
Post by SteveM » Sat Oct 17, 2020 8:11 pm
I bought two sine grinding vises at an auction, kept one and I'm selling the other,
It's an import (all the screws are metric).
The base is about 7-1/2" long and 3" wide. The jaws are 3" wide and 1-1/2" tall and the movable jaw has vertical and horizontal grooves cut into it. It looks like it opens about 4-1/2".
It's missing one of the two quadrants, the hemispherical segment that goes in the movable jaw and the nut. I started making the nut, but my metric taps are so bad, I stopped because I can't thread it far enough. It needs to have the sides milled, the hole for the rod drilled, and the hole tapped thru. The rod is a cut-down grade 8 bolt.
There is a slight oops on the top of the movable jaw, but the rest of the vise looks fine.
It looks like this one from Shars:
https://www.shars.com/products/workhold ... -sine-vise
The one I kept cleaned up nicely. No reason to think this one won't look as good.
$50 shipped anywhere I can send a domestic medium flat-rate box.
SteveM
Re: 3" sine vise
Post by SteveM » Sat Oct 17, 2020 8:12 pm
BTW, here's the one I am keeping post-cleaning, to give you an idea of what it should look like with the application of a little elbow grease.
Russ Hanscom
Re: 3" sine vise
Post by Russ Hanscom » Sun Oct 18, 2020 10:30 am
I would like it. paypal? To what address?
Thanks,
