FOR SALE--20" Rockwell 28-365 Variable Speed Bandsaw ****SOLD****
Buying, selling, trading and for giving away Items of interest to the Home Machinist Community. (Non-Commercial Only) *PLEASE BE SURE TO LIST CONTACT INFORMATION AND LOCATION OF ITEM*
tommy1010
Post by tommy1010 » Mon Nov 22, 2021 5:43 pm
As the title says I have a 20" Rockwell 28-365 Variable speed Bandsaw for sale. It came from a school shop years ago. Sat unused until I found the time and effort to get it back in shape. I has new tires ($270.00). These tires have the slot and are urethane. New bearings whether they were needed or not. Transmission completely disassembled and new oil filled. This transmission has the low and high speed selector. The cabinet was completely blasted inside and out. There is not a trace of bondo anywhere on the cabinet. Has extra zero clearance inserts for the table. The table tilts both ways. A couple of shop made blade guides along with some factory ones. Comes with a reproduced manual. It is powered by a THREE PHASE THREE HORSEPOWER motor currently wired for 208/220/240 three phase. Comes with a fully functioning magnetic starter. The 2 drive belts on the variable speed are new. It has wheels to move it around that can be removed very easily if you choose. The wheels only raise the machine 1" off the floor. You can start and run if you like. I only have one blade (142") and it is installed on the machine. I never did get any other blades as I feel the final owner will decide what type blades he needs. I can help load this. It weighs about 900 lbs. PM me with any questions. I am asking $1450.00 for it. It is ready to cut metal or wood.
SteveM
Re: FOR SALE--20" Rockwell 28-365 Variable Speed Bandsaw
Post by SteveM » Mon Nov 22, 2021 6:01 pm
Nice looking machine, and the price looks pretty reasonable when you consider that a 20" grizzly is almost seven grand.
You should list the location, as that's not going to fit in a flat-rate box (certainly not under the 70 lb limit).
Better yet, put your location in your profile and nobody will ever need to ask again.
BigDumbDinosaur
Post by BigDumbDinosaur » Mon Nov 22, 2021 6:36 pm
As the title says I have a 20" Rockwell 28-365 Variable speed Bandsaw for sale...
In which part of the Solar System is this machine located? You probably won't get much interest until readers know where they would have to go to pick up the saw.
Research is what I'm doing when I don't know what I'm doing.
tommy1010
Post by tommy1010 » Mon Nov 22, 2021 7:08 pm
Thanks. I don't know how I missed that part. I live in Northeast Pa. Hazleton area 5 miles east of Interstate 81 and about 10 miles south of Interstate 80. Zip is 18225.
partime
Post by partime » Tue Nov 23, 2021 9:32 pm
Seems like a great deal to me. I wish I live across the state instead of across the continent and a different country!
tommy1010
Post by tommy1010 » Fri Dec 03, 2021 10:27 am
The bandsaw has been SOLD. Thanks!!!!!!!!!!!
