Patio's projects
Moderators: Harold_V, WJH
liveaboard
Re: Patio's projects
Post by liveaboard » Tue Sep 01, 2020 7:22 am
All that time to make a tool to fix an old flashlight, that's just crazy.
It's good to know I'm not alone.
Patio
Post by Patio » Sun Sep 13, 2020 10:30 pm
Liveaboard, yeh, your not crazy either. ;)
Here are a couple of screws I made for the stops on the tracer. I started with a 8mm class 10.9 grade bolt. It was not a fully threaded bolt. I cut the head off, spun it around in the collet, picked up the existing threads and cut the threads just longer than what was needed. Put the bolt in a collet block and made the flats with the same distance from the treads. Back the the lathe, and shortened both ends to proper length.
Top one is new, bottom it original. The little divet, is from a wrong move, while picking up the threads.
This is the device it mounts in.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Patio
Post by Patio » Sun Sep 13, 2020 10:41 pm
A while back, I bought a Hemingway, Mini Rotary Broach kit. It is capable of broaching an 8mm hex. The kit arrived, with the box split opened and material missing. I can say, the customer service at Hemingway is outstanding! They sent out the missing material, right away. I started to make the parts today. We will see how it goes.
Here are the first two finished parts.
Lots of projects in motion right now! But it keeps me off the streets. :)
Forgive the past!
neanderman
Post by neanderman » Wed Sep 16, 2020 3:39 am
Impressive!
Ed
Le Blond Dual Drive
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Patio
Post by Patio » Wed Sep 16, 2020 11:38 pm
Neanderman, thanks!
Tonight progress. All the counter bores are done and the end is threaded 20mm X .5.
The side facing out is not finished yet. It will get faced off once the inside parts are installed.
Forgive the past!
liveaboard
Post by liveaboard » Thu Sep 17, 2020 5:21 am
20x.5; that's a really fine thread.
Nice looking work, as usual.
Patio
Post by Patio » Mon Oct 12, 2020 12:06 am
Did some painting this weekend, so I painted the Steady Rest, that I rebuilt to fit the Cazeneuve lathe. I used a little JB Weld to mold the bottom plate to the upper steady.
You can see that here.
https://www.youtube.com/watch?v=INcWJYFvSkQ
This is not a show job, more of a scuff and paint. It looks a lot better than before, and I am happy with it. Here is a picture.
Forgive the past!
curtis cutter
Post by curtis cutter » Mon Oct 12, 2020 8:48 am
Pat,
I am not sure they use JB Weld on the F15E Eagles but I like the video.
Seems the rain has driven us both back into the shop. Fall arrives in Washington.
Gregg
Patio
Post by Patio » Mon Oct 12, 2020 12:00 pm
LOL oops! Thanks for the heads up on the bad link. It is kind of a neat video though.
I tried to link this one, so people could see where I had installed a new base onto the Steady rest.
viewtopic.php?f=24&t=89632&start=456
About midway down the page, is the proper place to look.
P
Forgive the past!
