Page 2 of 2
Re: First (successful) attempt at a lathe project: drill arb
Posted: Thu Oct 30, 2014 7:34 pm
by Jawn
I did some more work on it today. There's still enough of a big end to grip and try turning it to 5/8".
This is how I cut the angle on the end. Just eyeballed the angle against a protractor as I clamped it. Measured diameter, then used an edge finder to put me on the mark, then figured up how far in to go to put the cutting edge of a 1/4" bit at the center. Also, I discovered I have no 1/4" bits. I thought I did... there's a 3/16" bit and a few 5/16" bits in my toolbox. Oh well. I'll get some before long.
On the bench before I cleaned the burrs off. Still need to drill/tap for the set screws.
Posted: Thu Oct 30, 2014 10:26 pm
by Patio
It is better to use a bit smaller than the slot you intend to make anyway.
Using a bit the size of the slot you wish to make, will usually end up over sized. So you did good. The work looks good too.
Posted: Thu Oct 30, 2014 10:43 pm
by Jawn
Patio wrote:It is better to use a bit smaller than the slot you intend to make anyway.
Yeah, I'd read that somewhere. Used a 7/32" end mill to make the slot, then shaved a little off each side to make it 1/4".
Looks like Harbor Freight has a small HSS assortment that appears to have a 1/4" square bit... I'll pick that up tomorrow if it's in store.
(same set has a parting tool in it too, something else I could use).
Posted: Sat Nov 01, 2014 1:51 am
by Jawn
I decided to go ahead and turn it down to 1/2" since the drill chuck arbor, center finder, and slotting arbor I have are all that size. Got it right on the mark this time. Also drilled and tapped for setscrews... however, I am concerned over the depth of threads (didn't have the exact recommended drill bit, went to the next 1/64" size up based on a prior experience involving a broken tap). Tap went in awfully easy, I'll thread some screws in and see how it goes. (need to pick up some setscrews tomorrow) Worst case, I redrill for a size up and put a 12-28 in instead of a 10-32.
HF did indeed have the little HSS bit kit with the 1/4" square, and it has inspired yet another project... it also came with a 1/4" round tool bit, so I'm going to make a boring bar or two to use that size/shape HSS. The QCTP I bought has a 5/8"-3/4" boring bar holder. So I cut a 5/8" bar to length, faced and chamfered the ends. Next I'll drill a hole through each end (one at 90 degrees, one at 45 degrees) and put a setscrew in each to retain the HSS bit.
Posted: Sat Nov 01, 2014 2:05 am
by Jawn
Action shot drilling the set screw holes. So it's relevant to the original topic, see the drill arbor in use!
Re: Making tools with my tools
Posted: Thu Nov 06, 2014 10:43 pm
by Jawn
I've updated the topic title to reflect the direction the thread has taken.
I've also made more goodies.
I finished the flycutter. Haven't had a chance to use it yet.
I made a boring bar for the lathe. The quick change tool post I bought came with a boring bar holder for 3/4" bar and came with a 5/8" sleeve.
I started by cutting a 6" piece of 5/8" 4130 steel rod (pre-finished to 5/8"). Faced the ends, drilled a 1/4" hole at 90 degrees at one end, and 45 degrees at the other end. Drilled and tapped a M5-.8 set screw hole at a 90 degree angle from the 1/4" hole. Just need to grind a 1/4" round bit down to a half-round at the end, and shape/angle it appropriately.
