One man's insanity---the story of an induction furnace
Moderators: Harold_V, WJH
Re: One man's insanity---the story of an induction furnace
Post by Harold_V » Mon Sep 24, 2018 3:05 pm
Thanks, Jim. That's likely to be useful when I finally start setting the two furnaces in place. Mean time, I picked up a huge radiator which will help dissipate heat. Got it at an auction, new, for only $40. A little damage to some of the fins, but that doesn't worry me. It, along with a little fresh water, should handle the heat I'll generate.
Ajax had warned (in the manual they provided) about not using water that was too cold. I understand about not operating at a temp where it will condense. Seems they recommend feed water temp around 90°F.
I doubt I'd ever have to run more than one furnace, although that may not be true. The power supply has provisions for two, but only one at a time can be operated, so I don't have to worry about compounding heat output.
Right now I'm working towards finishing the muller I rebuilt. When that's done, as well as the gib crane that will handle the ladle, I'll then start assembling the furnaces and the casting area. I have to finish the other projects first, as I won't have access with my fork lift once the furnaces are in place.
Way too much work, and not enough time, but we're making progress. :-)
DavidF
Post by DavidF » Mon Sep 24, 2018 6:24 pm
but I didn't anticipate the 20 years of lost time in building our shop and house
You could have saved a lot of time by just buying the lumber instead of planting seeds and waiting for trees to grow.. :lol: :lol:
In all seriousness though, I do understand how life loves to throw us curve balls and admire that your are still pushing on with your endeavor and looking forward to seeing the end results.
So that being said, stick the nose back to the grind stone and get on with it!! :D
Patio
Post by Patio » Thu Jun 06, 2019 12:50 am
I had a chance to make it up to Harold's place the other day and I took some pictures while I was there, that you might all enjoy.
I will let Harold answer all the questions about the specifics of the machines.
The Muller:
The furnaces and their base:
The jib crane:
More on the next page!
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Patio
Post by Patio » Thu Jun 06, 2019 1:03 am
The ladle:
In this picture, Harold is demonstrating how the ladle will be tipped to pour. In the background you can also see the Riddle and Muller.
These pictures were taken in April, it is now June, and a lot of progress has been made, since this time. Harold is now working on the last major part of the system, the cooling unit. He is at this every day, so I expect sometime this summer, a melt will be tried. :)
Enjoy!
Forgive the past!
spro
Post by spro » Thu Jun 06, 2019 3:36 am
cool. all i can type now.
rrnut-2
Post by rrnut-2 » Thu Jun 06, 2019 8:20 am
Looking good!
Jim B
