9/1/02
Got the home built bench-mounted wire EDM working 2 nights ago? Is this thing neat! A month ago I posted questions about some problems and thanks to some pointers received here, I got it working.
I'm using a power supply from Robert Langalois's book, "how to build an EDM". The greatest problem was the wire breaking. Got a Variac (varies AC output) so I could vary the AC voltage in, hence vary the DC out. Originally I used full power (70 volts) but with the Variac 55 Volts does a good burn w/o breaking the wire.
The x/y axis is controlled by 24 v DC gearmotors, also home made One of the reducing gears double as an encoder with 50 holes drilled eq space. 1/2-20 threaded rod acts as a feed screw so each drilled hole in the gear is .001" movement. The counts go to a Micrologix PLC which starts/stops/reverses the appropriate motor to make rectangular movement. There are also manual switches for freehand burning. Already made some key chains for buddies. Holes and angles will be next.
Home built Wire EDM
Home built Wire EDM
www.outbackmachineshop.com
