Hey Guys:
In my Profession in Aviation Upholstery, I have many types of scissors in my shop, to cut anything from your very fine materials to heavy leather. So to keep a very sharp edge on all my scissors, I made this sharpening jig.
It stems off of "the universal scissor sharpener", which what I thought was absolete until I machined this one. I have coarse/medium and medium/fine stones to get an incredibly sharp edge. I only take off a few thousands at a time vs quite a bit more using a motorized grinder. I used my Bridgeport Mill and my 10x24" Clausings lathe and cheated a bartender out of a couple of nights on this project.
Later,
NDAV8R
Scissor Sharpener
SHARPENER
Lovely tool!!
Thanks for sharing it.
- Steve_in_Mich
Very nice build there.
I keep our pet grooming scissors sharp using a Foley 327 Scissor Sharpener. It gives a hollow grind which may or may not be an advantage - I don't know because I don't use the scissors, I only sharpen them for those that do.
I would need a slick setup like you made to compare the two, straight vs. hollow grind. Have you compared the two grinds?
Hello Steve:
I was told once that hollow ground will have good cutting characteristics as it wears down a little. It probably will not need sharpening as often as a straight sharpened scissors. But I don't know for sure about it because all of mine including my expensive WISS scissors are Straight ground.
Gale Hansen
Valley City. North Dakota
Gale Hansen
