Pic of shop & some projects
Moderators: Harold_V, WJH
JackF
Re: Pic of shop & some projects
Post by JackF » Wed Jun 30, 2010 3:11 pm
Hi Steve,
Sounds like a neet set up. I don't know anybody who might need that stuff. I am a member of "Club Hot Rod" .......www.clubhotrod.com/forums/...! They have a "Parts for Sale" section that may be a help to you. I believe you would need to be a member but it cost nothing and you might like browsing the site. :wink: :wink:
Jack.
Post by GlennW » Wed Jun 30, 2010 3:50 pm
I'm pretty sure I still have some original '32 and '34 Ford front and rear cross members in the "archive". I sold what I thought was the last of the Hot Rod stuff about seven years ago, but a bit pops up now and then.
I'll have to dust off those brain cells and try to remember what's hidden in the corners. :)
JackF
Post by JackF » Sat Jul 03, 2010 7:21 pm
Here are some more pics.
In one of my earlier posts I mention the Wilson Welding hubs I bought to adapt the Buick drums to the Ford spindle but didn't show a pic of them. Instead, I showed a pic of a spacer I made to adapt the Buick backing plate to the Ford spindle. I have now loaded a pic of the Wilson hubs. I also elected to show some wall art and the start of the gas tank cover repair.
Jack.
Wilson Welding hub on Buick drum
Eddie Meyer heads
Any body from Sacto know anything about the "Pushrods"?
Gas Tank cover needing repair
Hole cleaned up and patch tacked in
Grill, show chromed 20+ years ago still waiting to be mounted
JackF
Post by JackF » Sat Jul 03, 2010 7:30 pm
Glen,
Forgot to answer one of your questions. I have owned it since 1966. This is a rebuild of my 1st build. This rebuild is taking longer than the original build. :roll:
Jack.
calgator
Post by calgator » Sat Jul 03, 2010 9:24 pm
Jack,
Finished cutting and mounting an adaptor that should have allowed the fallow rest mount but it moves the rest almost 2” greater away from the cutting head. Unfortunately this allowed for chatter when cutting, so I’m now going to move the scale to the back side. If I position it just right it will allow for access to the oiling points and the carriage locking bolt when moved from one side to the other.
Will post pictures latter tomorrow after I’m done with the fix.
Charles
The best times were behind one of Al's engines
JackF
Post by JackF » Sun Jul 04, 2010 9:18 am
Charles,
Thanks for the update. That was a good lesson learned on scale placement.
Jack.
calgator
Post by calgator » Mon Jul 05, 2010 1:45 am
Jack,
I may have a solution that still lets me have the scale on the front. because if I put in behind the cross slide it would block access to the carrage lock and I've found I use the lock quite a bit. when I finish cutting a new spacer for the front I will post pictures if it works.
Because I just can't give up on a good idea...
Charles.
JackF
Post by JackF » Mon Jul 05, 2010 9:22 am
Charles,
Keep us posted as I would love to uncover my gib screws.
Jack.
AllThumbz
Post by AllThumbz » Mon Jul 05, 2010 12:38 pm
Jack,
I love your shop building.
I want to expand my garden shed to be able to operate my woodworking machines in there (and keep the dust in thee rather than in the house), and was wondering if you had recorded the framing process in photos...
Thanks,
Nelson
JackF
Post by JackF » Mon Jul 05, 2010 9:53 pm
Nelson,
I did take some photos as I was building the shop. They were before I went digital so I will dig through the piles to see what I can find, I know I skipped some or maybe even many stages. Will scan them and post themas soon as I find them.
Jack.
calgator
Post by calgator » Wed Jul 07, 2010 2:19 am
JackF,
Well here is the adaptor that allows me to keep my glass scale on the front and still be able to attach the follow rest. I’ve made modifications to the follow rest to get a tight contact with the adaptor that then has a very close tolerance with the cross slide.
I may still fabricate my own followrest but this will work for now if I need to use it.
Charles
The steady rest side of the adaptor
cross slide side of the adaptor
the scale attached to the adaptor on the cross slide side
followrest machined for a close fit to adaptor to remove slop
8mx90mm bolts through followrest and adaptor that attaches to cross slide
followrest attached to adaptor and scale still works
When the followrest is not needed a spacer allows the same bolts to be used.
JackF
Post by JackF » Wed Jul 07, 2010 9:25 am
Charles,
Beautiful job. I will take a good luck at this to see if I can do the same. Is the adapter steel or alum.?
Jack.
