Drawbar Hammer wrench
Moderators: Harold_V, WJH
737mechanic
Post by 737mechanic » Mon Dec 27, 2010 10:14 pm
Got tired of using my 3/4 wrench to tap my drawbar to unseat it so I made a drawbar wrench/hammer.
The parts are 7/8 brass rod a cheap tiawan 3/4 impact socket and and a piece of titanium rod that I get at work. I first bored out the impact socket and single point threaded it. Then I threaded the brass to fit the socket then drilled and threaded through both the socket and brass to make sure they would never loosen from one another. I then threaded the titanium rod and using locktite for studs I screwed them together.
All in all it turned out ok except for the knurling on the handle but since my knurls are pretty dull and the titanium is hard I didn't worry about doing it again as the crappy looking knurls will do there job just fine.
Raw parts
steamin10
Re: Drawbar Hammer wrench
Post by steamin10 » Tue Dec 28, 2010 12:52 am
I bet it works good.
Nice fine threads.
737mechanic
Post by 737mechanic » Tue Dec 28, 2010 4:42 pm
Works much better than the old craftsman wrench I was using. The threads that hold the brass to the socket are 28 tpi. If I thread something that doesn't need any specific thread pitch I usally use 28 tpi becasue it seems to be a good all around pitch and since my lathe does not have a QC gear box I have to change gears to get the different thread pitches so I tend to leave it on 28 most of the time.
EdK
Post by EdK » Tue Dec 28, 2010 5:41 pm
Nice job on the tool :!:
One question though, aren't those impact sockets hardened? Seems like it would be tough to thread if it's hardened steel.
Ed
737mechanic
Post by 737mechanic » Tue Dec 28, 2010 10:36 pm
Impact sockets are softer than a good normal socket which is why they down chatter when you are hitting them with a impact. Also I am sure the tiawan impact sockets are even softer. I wasn't sure at first if I was going to be able to bore it and thread it but after doing a test run and seeing how easy it was I knew it was going to be doable.
EdK
Post by EdK » Wed Dec 29, 2010 5:32 pm
Thanks for the info on the impact sockets. I just may have to copy your tool. :)
Ed
NorrisM
Post by NorrisM » Tue Jun 14, 2011 10:04 am
How much lighter is the titanium over using a steel handle? It looks good especially with the titanium handle. How does titanium stand up to stress and time? Is it harder but more brittle than steel?
Anyone ever use a rapid prototype specialist for a project?
Bruce_Mowbray
Post by Bruce_Mowbray » Fri Jun 17, 2011 7:46 am
Brilliant!! I have seen guys braze a huge blob of brass on the open end of their 3/4" wrenches to act as a soft hammer, but yours is a far better idea.
Bruce Mowbray
Springville & Southern RR
TMB Manufacturing & Locomotive Works
