Bill, quite an interesting little setup that Craftsman saw was. Still, a blind uncle is still better than no uncle.
I also used lots of glue on all the joints, plus a few screws, some that cost me 14 cents each, but worth the money I think, as I only want to do this once.
Jack, the cops never showed up, so maybe I got away with it.
I have really enjoyed using the table saw. It got some good use, putting the camper back together. It was a bit of work and It came out better than I imagined it would, so I am petty happy with the outcome. Here are some pictures of the finished project.
In this picture you should be able to see the few tears that happened during "The incident".
The are filled with silicon and should hold up.
There are two tools that made this project successful.
The first one, was a cordless oscillating saw. The lower edges of all the exterior panels, are stapled to the wood framing. I used the saw to cut all the staples, by cutting into the wood just a little bit, behind the sheeting. It worked quickly and with out much damage to the panels. Also used the saw to cut the old rotted framing from the interior panels. They are glued together, and the saw cut the glue with out damage to the interior wood paneling. It was also came in handy when trying to cut off small lengths off of the 1.5"X1.5" new wood framing, during the fitting process.
The second tool, was a Harbor Freight T-50 pneumatic stapler. It had he power to seat the staple, through the aluminium panels. cost less than 30 bucks.
We did have a chance to use it over the Holiday weekend, while camping with friends, down by a river.
We are going to go for a ride to northern California, on one of the bikes. I usually fly an American flag, as the flag pole is handy for packing the gear. Got a new flag, from the our local Veterans museum, and had to fit it to the pole. I made a brass ring to allow the bottom stand off, to fit any sized flag.
That's if for this post, thanks for looking.
