Bits
Moderators: Harold_V, WJH
Russ Hanscom
Bits
Post by Russ Hanscom » Tue Dec 06, 2011 6:39 pm
It was 7F outside this morning, and a high of 28, so I do not feel guilty about a little shop time. One of the multiple ongoing projects is making parts for a B&S tool and cutter grinder. It is missing most of the attachments so I am going through the manual sort of copying pictures of things. The little arms that hold a diamond for wheel truing need three thunb screws - here they are. The actual head dia is 3/4". Made from mystery steel, the knurls turned out nice but there is slight tearing on the flat surfaces.
wsippola
Re: Bits
Post by wsippola » Tue Dec 06, 2011 8:14 pm
Hi Russ,
They came out nice. Not sure from the photo, but they seem to be darkened. If so, what process did you use?
Wayne
Russ Hanscom
Re: Bits
Post by Russ Hanscom » Tue Dec 06, 2011 9:59 pm
They really are normal shiney steel - blame a poor camera operator for the finish color!
