Gas Turbine ECU/Fadec
Moderators: Harold_V, JackF
hobbysteam
Post by hobbysteam » Wed Oct 28, 2020 12:48 pm
Hello
I'm not sure if this request belongs here but here goes. Has anyone out there successfully assembled an ECU for a small gas turbine using Arduino UNO 3 or Mega boards and got it to where it is a useful engine controller. I have sourced my converter boards for the Hall tach, the K type EGT and the pressure transducer but I could use all the help I can get. If anyone wants to chime in here it would be much appreciated!
Thanks
Bob3700
Re: Gas Turbine ECU/Fadec
Post by Bob3700 » Thu Feb 04, 2021 3:36 pm
U might have better luck with this question on an R/C Airplane forum. I have worked on the full sized equipment but only have very limited exposure to smaller/model sized engines. The one's I saw utilized fuel pressure to change engine speed. The controller was a purchased item for operating the engine and was tied into the transmitter box for the flight controls.
Bob
