Radial Diesel Engine
Hello everyone. I am brand new, with little machining experience, and no typical machining tools.
I would say that my only experience was using the metal lathe in shop class in high school, and making a C-clamp using ony simple hand tools in my standard practices lab here at SAIT. This was a requirement for all Aircraft Maintenance Engineer Technology students, and my first time trying to meet very precise tolerances. It was an excellent learning experience.
Anywho, due to the development of diesels for small planes, and also loving the power in my 97 powerstroke, I wondered if anyone has ever tinkered with the idea of a radial diesel engine.
If so, please drop me a line.
Rustytools
Rustytools
Depends
On what you definition of 'small airplane' and 'diesel' include...
http://www.horizonhobby.com/Shop/ByCate ... SAIE325R5D
this is for a small airplane...and, believe it or not, it is a diesel...more commonly called a glow engine, but still a diesel....
Bill, a Diesels and a Glow engine are very much different animals...
A Diesel ignites the charge from compression heat alone, whereas a Glow engine has a wire coil that continues to "glow" from the heat of the previous cycle, and ignites the consecutive charge...
Glow engines generally use methanol as fuel, where a Diesel will use either...
SATO's are glow engines, and I don't think they have any diesels in their product line.
[b]Bryan[/b]
[i]"Simplicity is the ultimate sophistication."[/i] Leonardo da Vinci (1452-1519)
Man, talk about a blast from the past...I had forgotten even posting that. I have always been intrigued by the Packard Diesel. Notice it has only one valve per cylinder? That D-shaped tube takes air in the front on the intake stroke, & blows exhaust out the back on exhaust stroke...neat, huh?hybidder wrote:ronm,
I would hate to have to "prop start" that engine on a cold winter morning.
That picture should be hanging a wall. Some of the old production engines really were works of art...
Like this?
Like this, maybe?J Tiers wrote:Absolutely. There was one pre-war. I'd have to look up the name, but it was IIRC a 5 cyl diesel and definitely radial. Guiberson, Gunderson, some name like that I think.
http://www.oldengine.org/members/diesel ... berson.htm
In 2005 there was a Packard radial diesel on display in the Warp
museum at Minden NB. There were many other old and unusual aircraft
engines. Just off interstate 80, Plan for a 6 to 8 hour stop. Hope its still
open. LynMn
open. LynMn
