Porosity holes in head casting
Moderators: Harold_V, JackF
Adrian
Post by Adrian » Sun Mar 04, 2007 5:41 pm
On a model engine cast iron cylinder head, a few minute porosity holes have been found in the casting around the valve seats. Is there any easy way to seal these up and it still be able to deal with the heat of the running engine.
There is not enough space to bore and fit new valve seats apparently.
I do not have the casting to hand, but seem to remember something could be done, but then again this may have been for none stressed parts.
Cheers
Adrian
Why do I always need to make the tools, to complete the work?
Orrin
Post by Orrin » Tue Mar 06, 2007 1:53 pm
I have used JB-Weld to successfully fill voids in castings. It should be able to withstand the temperature.
Orrin
So many projects, so little time.
Adrian
Post by Adrian » Tue Mar 06, 2007 2:49 pm
Still waiting to get the casting back to see. When I get it I will have a play.
Adrian
