Page 1 of 1
Grizzly 9729
Posted: Sat Feb 14, 2009 10:04 am
by cobra
I have ordered a Grizzly 9729 and I am in the midst of building the table/stand for it.
Does anyone have the distance between the bolt holes on the feet?
I am welding in supports under the top of the table.
Thanks
Jim
Re: Grizzly 9729
Posted: Sun Feb 07, 2010 2:09 pm
by jj39
Hello,
i will share the stand that i built for mine
it is 36X60X20 on the 6 inch casters it sets at 26.5 inches high .
the specs you asked for drilling your 1/2 inch bolt holes are
41 5/16 length and width is 5 3/4
you will need to run a tap through your holes as they should have paint
in them mine did . if you have any other questions post back i will check back to see if i can answer any other questions . my small shop is 1/4 of a 24X36 metal building i also have a HF 5980 3in 1 machine i do all kinds of small projects from firearms to making parts for 4wheelers .
i know you asked about this in 09 but i replied for others that may have the same questions .
JJ39
cobra wrote:I have ordered a Grizzly 9729 and I am in the midst of building the table/stand for it.
Thanks
Jim
