greetings,
was wondering if anyone had any recommendations on some boring tools that will fit well into the toolpost of the V10.
after looking in grizzly and MSC, it seems like most boring bars have a large diameter shank, which doesnt fit well in the tool holder.
i am doing some light small boring, so i was thinking maybe i could just heavily relieve a 1/4" blank toolbit. the only problem with this is i have very little experience grinding tools. no time like the present to learn, eh?
boring on the emco v10p
Re: boring on the emco v10p
It is generally accepted that small holes are bored with hand ground toolbits. It's a skill that is mandatory if you hope to not be held captive by commercial tooling. It's not nearly as hard as it may appear, but do expect a small learning curve. No better way to see the results of your efforts than to try the tool. When it doesn't cut well, look at it carefully to see where it's rubbing. Be mindful of relief, and rake, where appropriate. No negative rake for HSS.niedz wrote:i am doing some light small boring, so i was thinking maybe i could just heavily relieve a 1/4" blank toolbit. the only problem with this is i have very little experience grinding tools. no time like the present to learn, eh?
I make my own boring bars from literally anything I have at hand ... that be a broken end-mill, tool bits, a round bar with a silver soldered carbide insert, etc.
For larger diameter boring bars I made this simple holder.
One for 1/2" and one for 5/8"
http://www.chaski.org/homemachinist/vie ... hp?t=76591
