That's an excellent solution to the problem, especially if it's a bastard thread, as it appears to be.MikeA wrote:The good news is that method I referred to via link that uses Acetal with a heat/pressure method to make an exact nut regardless of the size. At least I have a viable alternative this way.
I'd be interested in hearing how it goes, so please do post the results you achieve. It would serve other readers well, too.
Good luck!
PS--I was just thinking. Delrin AF is Teflon filled acetyl. I don't know if it would respond to the forming process, but if it would, it would be an excellent choice for the nut. I used to make a nut for metering pumps from the material, for Becton Dickinson Pharmaceutical. It's very nice to machine, if you haven't worked with the stuff.
