Sold 4-4-0- 999 Locomotive Sold
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Painter590
Post by Painter590 »
Reduced $1,300
Painter590 wrote: I was asked about the bore and stroke of the of the cylinders. I have know idea but I did take some photos. I think it is 2 inch bore. And the length of the cylinder is 4 3/8. Which I don't now what the stroke would be. Reduced to $1,600. There is 13 small wheels. Even though the photo shows 11.
I have posted this stuff before in live steam forum.
Here is a Linkhttp://www.chaski.org/homemachinist/vie ... =8&t=99980
To find out what it is. Since then I have found out it is indeed from a 999 that Leo Meyer - Neil Pittneger had started on. I have talked to Joel and he has castings - prints. Other info on this locomotive.
As for if the boiler was built in a Monsanto shop. I have not confirmed.
But would guess it was. As my camel back had the flues silver soidered.
Also Joel's boiler had them silver soidered in.
I can confirm that the boiler was hydro tested to 200 lbs and had no leaks what so ever. The tubes have been silver soldered in. If you do decide to purchase this boiler,castings. And flat steel.We can pressure test the boiler to any pressure you would like before buying.
Reduced $1,400 for Every thing that I have for the 999 Locomotive. I would like for the buyer to pick up.
Gene Buffard
Painter590
Re: American 4-4-0- 999 Locomotive castings & boiler
There are 13 of the smaller wheels.
4 of the larger drivers. 2 of the drivers have been cleaned up. No sharp casting burrs.
There are 6 axles for the small wheels.
2 axles for the drivers.
Gene Buffard
Painter590
There are 2 pieces marked 999 frame.
There are also 6 other pieces of flat steel. That I am guessing are for the connecting rods for the
Gene Buffard
Painter590
Here are the castings. For the Pistons and smoke box.
Gene Buffard
Painter590
Forgive me if call something by the wrong name. Brass - bronze axle bushings.
The 2 other cast items I believe go on the back side of the piston castings for the seals. Where the drive Pistons rods are.
Gene Buffard
Painter590
Re: REDUCED $2,500 Mid Sourh delivery 4-4-0- 999 Locomotiv
I can deliver to Mid South if some one is wanting to buy 999 stuff.
Gene Buffard
Painter590
Re: REDUCED Again $2,200 Mid Sourh delivery 4-4-0- 999 Lo
Today is my birthday. So I reduced it to $2,200
Gene Buffard
Painter590
Re: REDUCED $2,000 how low will it go 4-4-0- 999 Locomotive
I
Gene Buffard
Painter590
How low will it go!!!
Gene Buffard
Painter590
Ok I was asked about the bore and stroke of the of the cylinders. I have know idea but I did take some photos. I think it is 2 inch bore. And the length of the cylinder is 4 3/8. Which I don't now what the stroke would be. Reduced to $1,800. There is 13 small wheels. Even though the photo shows 11.
Gene Buffard
Painter590
Re: REDUCED $1,800 how low will it go 4-4-0- 999 Locomotive
There is a post in the Live steam section that talks about these casting parts and boiler that I bought at auction . Here is a link.
Gene Buffard
Painter590
Re: $1,300 REDUCED $1,300 4-4-0- 999 Locomotive.
Monday 5-18-15 reduced $1,300
Gene Buffard
