This is a project that has been under my bench for 3 years and needs a new home. I purchased this some years ago and found the original build to be lacking in quality. I basically took everything apart and started from scratch.
- New frames, binders and spreaders. Bolted to existing pilot and cylinders.
- New axel boxes, Timkin roller taper bearings and races, grease able through axel centers.
- Re-bored driver axel hole true to existing steel tire, new keyed axels and rekeyed drivers.
- New side and main rods with bronze bushings
- Hardened and ground rod journals
Cylinders where not originally bored parallel they need to be reworked so the crossheads/ bores align with the rest of the engine.
All new pins and axels where pressed fit.
7.5" Gauge, 10" drivers, 56" long from front coupler to draw pin.
Includes springs, not equalized.
I have no idea who made the original castings.
Engine rolls super smooth and will fall off the stand, with the side rods on, if you are not carful!
I will be driving from Milwaukee to Harrisburg PA in two weeks and can drop off anywhere along the way, or deliver to Godshalls shop. Or you can pick up in Milwaukee.
Asking $2,000.00
