I recently needed some miniature decorative valves so I set out to model them and have them cast. They are non-functional, but have an open center so they will pass air, oil, water, or steam. I produced two sizes, one to accept ø1/8” tubing and the other to accept ø3/32 tubing. They can also be used with solid rod if the application does not require movement of a fluid. Cast from bronze, they can be soft soldered or silver soldered.
The ø1/8 tube Globe and Angle valves are $13 each plus shipping
The ø3/32 tube Globe and Angle valves are $8 each plus shipping.
PM me if interested
Sub Miniature Globe and Angle valves by Keim Steam Pump
- Chris Hollands
Re: Sub Miniature Globe and Angle valves by Keim Steam Pump
I'll take some off you Brian , let me work out numbers .
Chris
Chris
- Chris Hollands
- Trainman4602
This is good news the hobby need this size badly. I see you at Cabin Fever on Saturday be sure and find me. Thanks Dave
