All,
Looking for anyone who has a side elevation drawing of a 1.6" scale cross compound air compressor showing the overall outline of the compressor and the location of the mounting holes. I just need this to make sure I properly locate the mounting brackets on the front frame spreader for a 1.6" scale C&O Greenbrier. I can work off of the erection drawings if nothing turns up, but figured using a full size 1.6" drawing would be better.
Thanks in advance,
Rob Gardner
1.6" Cross Compound AC Drawing Needed
Re: 1.6" Cross Compound AC Drawing Needed
Rob,
Try this; http://www.nelsonslocomotive.com/Heisle ... essorI.htm or this; http://www.grandscales.com/downloads/index.html. Grand scales has the Westinghouse Cross compound compressor pamphlet available in 3 parts.
Now if you come across a set of Superscale drawings , or other drawings that have dimensions to machine from let me know.(Any scale will do) Also looking for a couple more sets of castings for the 3" scale pump Railroad Supply offered in the early 60's.
Nyle
Nyle
Thanks, Nyle!
Rob
Rob
Thanks to everyone who reached out to me back channel. I think I will have all the drawings I need to move forward now.
Rob
Rob
