TAKING ORDERS FOR HANCOCK CHECK VALVES
Posted: Tue Jul 31, 2018 6:23 pm
I finally got around to making up the check valve prototypes. They will be available in a few weeks. You can get them in either flanged or spanner nut styles. I will have a limited number of elbows available at an extra cost.
The valves feature a top shut off that can be utilized to clean the check valve while under steam if needed.
All the seats and gaskets are “O” rings and the hardware is stainless steel.
You can get the boiler flange fitting in a 1/8 male NTP pipe or a 1/4 NTP male boiler fitting, included with the valve.
The supply fitting is for 5/16 OD tubing solder connection.
Prices as follows
Flange fitting $225.00 each
Spanner fitting $225.00 each
90 degree Elbow $ 50.00 each
Shipping in the USA free foreign orders shipping will be extra.
PM me to get on the list
PS as this is a new product I only have about 30 body castings I will have more soon.
Prices as follows
