Little Engines 1 1/2" scale AXLE DRIVEN Water PUMP
This pump is almost ready to be installed. The only maching left is finishing the rod end that hooks to the axel pump plunger. The excentric is Split ( two Halves that bolt together so axel doesn't have to have wheel removed for installation . Excentric is bored for 1 1/8" axel. The pump bore is 3/4" and has a 1" stroke.Water Inlet to pump is 5/16" and top is not been threaded . Drilled for 5/ 16" . Original print is included and is very readable. These pumps were used on 1 1/2" Atlantics and Pacifics Due to there size I would say that this pump could be used on other style engines. Overall lenght from excentric to end of pump body is about 11" . Pump body by self is 3 1/2" LONG. 1 " wide and 3" overall at check valve outlets. Price which includes shipping is 265.00 . PM me if interested and thanks for looking at my listings. Postwarbob
