This valve is the Rolls Royce of throttle valves and very expensive , Jim Kreider uses these on his Berkshire engines but it is to small for the
Challenger so it can find a new home - the valve is brand new never used .
It is a Swagelok 1/2" true thermal ball valve rated at 1000 psi @ 850F all S/S with 1" compression fittings , and the best part about Swageloc valves
you can get rebuild kits for them if required .
The compression fittings can be reduced in size to suit as standard reducers will fit .
The linkage on the valve is from Jim's throttle drawings and can be RH/LH position .
To replace this valve with the compression fittings would be over $500 US .
Asking $395US includes postage in N America - paypal if you want to
Throttle valve
- Chris Hollands
